newbie question - dish
DEFman
I have a HughesNet dish (32"x26") and LNB.
Can these be used for FTA?
If so should I use a motor or muliple LNBs?
Should work ok as a fixed dish, or, with some modifications, as motorized. Little on the small side, but should get most of the programming and feeds. Dish can be skewed properly if you leave the original mounting hardware on it. You can remove the transmitter part of the lnb, and the mount if you decide to put it on a motor. (they're pretty heavy with all that in place) If it's the white dish, I have one, built like a tank, durable.
Anybody use Coolsat 8100 HD ?
Need comments on Circ Polarization & pkg.
