Hey everyone. Please help me out with installation hardware selection. I am very overwhelmed with all the options/combos. This is a long post so I have tried to simplify it....
I am considering coming back to DirecTv after a 6 month hiatus. I moved during that time and am pretty sure I am going to get DirecTV back (alternative is Comcast = $$$)
WANTS/NEEDS:
I would like HD. In the new house, I have up to 8 locations for wathcing TV. I would also like to pass through the TV antenna for local free HD broadcasting (UHF/VHF). I also have a HTPC (home theater Personal Computer) in the family room that I would like to do DVR with
CURRENT WIRING:
The house currently has an older dish on the roof that I do not think works for HD. There are four lines coming into the attic from the roof (2 are not attached to anything) The wires go through the attic vents so I can easily add or remove them.
There is a low voltage media center in the attic and basement (2 story house with basement) the second floor has five rooms and all coax goes up into the attic and to the attic media panel. The basement and first floor coax runs go into the basement media panel and then to the rooms.
EQUIPMENT:
I have 3 non HD recievers. May wnat to use 1 or 2 for old non HD TVs that I have. Have HDTV antenna to install. Would like to use a SWM dish so I can have only 2 wires going from roof to attic (one for dish and one for antenna)
QUESTIONS (I know I know, it took a little while to get here)
1. What satellite dish should I get? Perfer SWM I live in Aurora, IL (Chicago burbs)
1a. Is the SWM LNB the only dish I can use to get local HD channels?
1b. Can I run more than 8 receivers with one SWM LNB?
1c. Can you run UHF/VHF TV antenna signals combined in the SWM coax?
1d. Shoudl I just use a Phase III dish?
2. Then what splitter/multiswitch? I can see needing a possible of 9 outputs, but can live with 8. Also would like to combine the Antenna feed.
3. Are crimp coax connectors OK? (Someone suggested some wierd expensive DirecTv special thingies.)
Thanks in advance.
WANTS/NEEDS:
CURRENT WIRING:
EQUIPMENT:
Thanks in advance.
