newbie help me please
nicko0
9
Florida, Hollywood
This is what i have wineguard ds-2076 dish, visionplus visionDTV sat pci card 1020a, digipower sg-2100 hh motor, dmsi spitfire standard ku lnbf. I mounted on pole plumb on side of house noting blocking it set up to latitude for hollywood fla zip(33021) where i live (26.02n)latitude. I pointed true south not magnetic then i moved to nearest satellite (AMC-5) and peaked with meter. then checked by moving motor from east to west an got in an out readings from meter as I moved it telling me i was on belt i guess. Then I went in side turned on software that came with sat card an i get no quality an up to 80% strength. I also tried other software progdvb,an my theater. Can someone give me some help pretty please be happy to see any picture. Maybe the card is junk it had good reviews but I think that was from distributor. No quality an when i click goto st says cant reach from here.
what is your true south bird... you will not see a picture with out being on an active transponder. (lyngsat may say its active but it really might not be) Let me know what your true south bird is so i can give you freqs to plug in to see if your on the bird.. also try doing a sat scan.. to see if you can pick anything up..
You will need to know your True South satellite, give us your zip code and we can give you all the angles needed : )
Code:
Hollywood, FL 33021
           Latitude 26° 1.308'N Longitude 80° 11.346'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                     Intelsat 901   18.0W 103.0 108.9 16.4 -61.1
                     Intelsat 603   20.0W 104.1 110.0 18.3 -60.6
                            NSS 7   22.0W 105.2 111.1 20.1 -60.1
                     Intelsat 905   24.5W 106.7 112.5 22.4 -59.4
                     Intelsat 907   27.5W 108.5 114.3 25.1 -58.5
                   Hispasat 1C/1D   30.0W 110.1 115.9 27.4 -57.6
                     Intelsat 801   31.5W 111.1 116.9 28.8 -57.0
                     Intelsat 903   34.5W 113.2 119.0 31.5 -55.7
              AMC 12 & Telstar 11   37.5W 115.4 121.3 34.1 -54.2
                          NSS 806   40.5W 117.9 123.7 36.8 -52.6
                        PAS 6B/3R   43.0W 120.0 125.9 39.0 -51.1
                           PAS 1R   45.0W 121.9 127.7 40.7 -49.7
                     Intelsat 705   50.0W 127.0 132.9 44.8 -45.8
                     Intelsat 707   53.0W 130.5 136.4 47.2 -43.1
                     Intelsat 805   55.5W 133.7 139.5 49.0 -40.5
                            PAS 9   58.0W 137.1 142.9 50.8 -37.7
                         Amazonas   61.0W 141.6 147.4 52.8 -34.0
           EchoStar 3 & Rainbow 1   61.5W 142.4 148.2 53.1 -33.3
                 Estrela do Sul 1   63.0W 144.8 150.7 54.1 -31.2
                     Brasilsat B2   65.0W 148.2 154.1 55.2 -28.2
                     Brasilsat B1   70.0W 157.7 163.6 57.5 -19.9
                 Nahuel 1 & AMC 6   72.0W 161.8 167.7 58.2 -16.3
                        DirecTV 5   72.5W 162.9 168.7 58.4 -15.3
                            SBS 6   74.0W 166.1 172.0 58.8 -12.5
                            AMC 5   79.0W 177.3 183.1 59.6  -2.4
                          Nimiq 2   82.0W 184.1 190.0 59.5   3.7
                            AMC 9   83.0W 186.4 192.2 59.4   5.7
                     Brasilsat B3   84.0W 188.6 194.5 59.3   7.8
                           AMC 16   85.0W 190.9 196.7 59.1   9.7
                            AMC 3   87.0W 195.2 201.1 58.6  13.7
              Intelsat Americas 8   89.0W 199.5 205.3 58.0  17.4
                 Galaxy 11/Nimiq1   91.0W 203.5 209.4 57.3  21.0
                     Brasilsat B4   92.0W 205.5 211.3 56.8  22.7
                        Telstar 6   93.0W 207.4 213.3 56.4  24.4
                        Galaxy 3C   95.0W 211.1 216.9 55.4  27.6
              Intelsat Americas 5   97.0W 214.6 220.4 54.3  30.6
                        Galaxy 4R   99.0W 217.8 223.7 53.1  33.4
                            AMC 4  101.0W 220.9 226.8 51.8  36.0
                            AMC 1  103.0W 223.8 229.6 50.4  38.5
                           AMC 15  105.0W 226.5 232.4 49.0  40.7
                          Anik F1  107.3W 229.4 235.3 47.2  43.0
         DirecTV 6 & EchoStar 6/8  110.0W 232.6 238.4 45.1  45.5
                          Anik F2  111.1W 233.8 239.6 44.2  46.5
                    Solidaridad 2  113.0W 235.8 241.6 42.7  48.0
                         SatMex 5  116.8W 239.4 245.3 39.5  50.7
          EchoStar 7 & DirecTV 7S  119.0W 241.4 247.2 37.6  52.1
  EchoStar 9/Intelsat Americas 13  121.0W 243.1 248.9 35.8  53.2
                       Galaxy 10R  123.0W 244.7 250.5 34.0  54.3
                        Galaxy 12  125.0W 246.2 252.0 32.3  55.3
             Galaxy 13/Horizons 1  127.0W 247.6 253.5 30.5  56.2
 Intelsat Americas 7 & EchoStar 5  129.0W 249.0 254.9 28.7  57.0
                           AMC 11  131.0W 250.3 256.2 26.8  57.8
                        Galaxy 1R  133.0W 251.6 257.4 25.0  58.5
                           AMC 10  135.0W 252.8 258.7 23.2  59.1
                            AMC 7  137.0W 254.0 259.8 21.4  59.7
                            AMC 8  139.0W 255.1 261.0 19.5  60.3
                     EchoStar 1/2  148.0W 259.9 265.7 11.3  62.2
        Satellite Finder is (c) Copyright 2004, P. Lutus
Motor Elevation =64 deg
Dish(On Motor) Elevation= 26 deg.
I would use AMC-5 as you true south satellite.
thanks alot i will let you know what happens but i dont know about skew settings how do i set that i see a guage on where lnbf is but no marks on lnbf how is this set pls
thanks for help getting ready for storm
With a motorized system the skew sets itself, the LNBF goes straight up and down for your true south satellite then as the dish/LNBF swings it lines up perfectly (skews) with the satellites in the sky!
There is also usually a "0" marked on the LNBF and or holder.
PLEASE USE PUNCTUATION!!!
It is a royal bitch for me to read these posts because theyre all jumbled together
Sorry I will try to use more punctuation. Katrina gone an power is back on after 3 days. Still need a little help please. I set my true south for hh motor magnetic variation 5.5w. Then I set elevation of motor at 64 an dish at elevation 26 Then tried to move dish to amc 5 by motor with go to sat an says cant reach sat from location. So i got dish pointed at amc-5 used sat finder tone with meter. I now recieve signal with sat finder an moved from east to west an picking up sats as i move the dish with motor . But I still get 80% red in strength an no quality pls help me anyone. Is this visionplus pci sat card junk or could it be the lnbf from dmsi spitfire.
Similar situation here. 36" fortec dish, Microroyal H2H motor, VP1020P card, DVB-TV software has a motor control section that asks for Longitude, latitude, degree and elevation. I'm not sure what to enter for lat and long. I know mine is N44 lat, 79 long W. When I try to use the USALS function go to sat location everything located to the west of me (Ontario, CAN) returns error message cannot see satellite from your location. If I attempt a sat from Europe which I know I cannot see the dish moves no error.
TIA for any assistance. The learning curve is large but I'm getting there!
Give us your zip code. You MUST have the lat. and long. entered correctly in order to track the arc. You will need pointing angles as well. Zip is first step.
I have the same problem. 65% level, 0% quality.
For the twinhan software, you need to put - (negative value) in longitude, then USALS will work.
zip 48105
36" fortech dish, STAB HH90 motor, fortech 0.4 universal LNB, twinhan 102G PCI card.
hyc05 Welcome to the SatelliteGuys.US FTA forum
Code:
                       Ann Arbor, MI 48105
          Latitude 42° 18.252'N Longitude 83° 42.408'W
                     Intelsat 901   18.0W 106.9 114.3  9.1 -45.0
                     Intelsat 603   20.0W 108.4 115.8 10.6 -44.6
                            NSS 7   22.0W 109.9 117.3 12.0 -44.1
                     Intelsat 905   24.5W 111.9 119.2 13.8 -43.3
                     Intelsat 907   27.5W 114.2 121.6 15.9 -42.4
                   Hispasat 1C/1D   30.0W 116.3 123.7 17.7 -41.5
                     Intelsat 801   31.5W 117.6 124.9 18.7 -41.0
                     Intelsat 903   34.5W 120.1 127.5 20.8 -39.8
              AMC 12 & Telstar 11   37.5W 122.8 130.2 22.8 -38.4
                          NSS 806   40.5W 125.6 133.0 24.7 -37.0
                        PAS 6B/3R   43.0W 128.0 135.4 26.3 -35.6
                           PAS 1R   45.0W 130.0 137.4 27.5 -34.5
                     Intelsat 705   50.0W 135.3 142.6 30.5 -31.4
                     Intelsat 707   53.0W 138.6 145.9 32.1 -29.3
                     Intelsat 805   55.5W 141.4 148.8 33.4 -27.4
                            PAS 9   58.0W 144.4 151.8 34.6 -25.5
                         Amazonas   61.0W 148.1 155.5 36.0 -23.0
           EchoStar 3 & Rainbow 1   61.5W 148.8 156.1 36.2 -22.6
                 Estrela do Sul 1   63.0W 150.7 158.1 36.8 -21.2
                     Brasilsat B2   65.0W 153.3 160.7 37.6 -19.4
                     Brasilsat B1   70.0W 160.1 167.5 39.2 -14.6
                 Nahuel 1 & AMC 6   72.0W 162.9 170.3 39.7 -12.6
                        DirecTV 5   72.5W 163.6 171.0 39.8 -12.1
                            SBS 6   74.0W 165.7 173.1 40.2 -10.5
                            AMC 5   79.0W 173.0 180.4 40.9  -5.2
                          Nimiq 2   82.0W 177.5 184.8 41.1  -1.9
                            AMC 9   83.0W 178.9 186.3 41.2  -0.8
                     Brasilsat B3   84.0W 180.4 187.8 41.2   0.3
                           AMC 16   85.0W 181.9 189.3 41.1   1.4
                            AMC 3   87.0W 184.9 192.3 41.0   3.6
              Intelsat Americas 8   89.0W 187.8 195.2 40.9   5.8
                 Galaxy 11/Nimiq1   91.0W 190.8 198.1 40.6   7.9
                     Brasilsat B4   92.0W 192.2 199.6 40.4   9.0
                        Telstar 6   93.0W 193.7 201.0 40.2  10.1
                        Galaxy 3C   95.0W 196.5 203.9 39.8  12.1
              Intelsat Americas 5   97.0W 199.3 206.7 39.3  14.2
                        Galaxy 4R   99.0W 202.1 209.5 38.7  16.2
                            AMC 4  101.0W 204.8 212.2 38.1  18.1
                            AMC 1  103.0W 207.5 214.9 37.4  20.0
                           AMC 15  105.0W 210.1 217.4 36.6  21.8
                          Anik F1  107.3W 213.0 220.4 35.6  23.7
         DirecTV 6 & EchoStar 6/8  110.0W 216.3 223.7 34.4  26.0
                          Anik F2  111.1W 217.6 225.0 33.8  26.8
                    Solidaridad 2  113.0W 219.8 227.2 32.9  28.3
                         SatMex 5  116.8W 224.1 231.5 30.8  31.0
          EchoStar 7 & DirecTV 7S  119.0W 226.4 233.8 29.6  32.4
  EchoStar 9/Intelsat Americas 13  121.0W 228.5 235.9 28.4  33.7
                       Galaxy 10R  123.0W 230.6 237.9 27.2  34.8
                        Galaxy 12  125.0W 232.5 239.9 25.9  35.9
             Galaxy 13/Horizons 1  127.0W 234.5 241.8 24.7  37.0
 Intelsat Americas 7 & EchoStar 5  129.0W 236.3 243.7 23.4  38.0
                           AMC 11  131.0W 238.1 245.5 22.0  38.9
                        Galaxy 1R  133.0W 239.9 247.3 20.7  39.8
                           AMC 10  135.0W 241.7 249.0 19.3  40.6
                            AMC 7  137.0W 243.4 250.7 18.0  41.4
                            AMC 8  139.0W 245.0 252.4 16.6  42.1
                     EchoStar 1/2  148.0W 252.0 259.4 10.1  44.7
Tex/Fluffy
Keswick, ON. Canada
Code:
          Latitude 44° 15.600'N Longitude 79° 27.000'W
                     Intelsat 901   18.0W 110.8 122.8 11.5 -42.0
                     Intelsat 603   20.0W 112.4 124.4 12.9 -41.5
                            NSS 7   22.0W 114.0 126.0 14.2 -40.9
                     Intelsat 905   24.5W 116.1 128.1 15.9 -40.0
                     Intelsat 907   27.5W 118.6 130.7 17.9 -38.9
                   Hispasat 1C/1D   30.0W 120.8 132.9 19.6 -37.9
                     Intelsat 801   31.5W 122.2 134.2 20.5 -37.3
                     Intelsat 903   34.5W 125.0 137.0 22.4 -35.9
              AMC 12 & Telstar 11   37.5W 127.8 139.9 24.3 -34.4
                          NSS 806   40.5W 130.8 142.8 26.0 -32.8
                        PAS 6B/3R   43.0W 133.4 145.4 27.5 -31.4
                           PAS 1R   45.0W 135.5 147.5 28.6 -30.1
                     Intelsat 705   50.0W 141.0 153.0 31.1 -26.8
                     Intelsat 707   53.0W 144.5 156.5 32.6 -24.6
                     Intelsat 805   55.5W 147.5 159.5 33.6 -22.6
                            PAS 9   58.0W 150.6 162.6 34.7 -20.6
                         Amazonas   61.0W 154.5 166.5 35.7 -18.0
           EchoStar 3 & Rainbow 1   61.5W 155.1 167.1 35.9 -17.5
                 Estrela do Sul 1   63.0W 157.1 169.1 36.4 -16.2
                     Brasilsat B2   65.0W 159.7 171.8 37.0 -14.4
                     Brasilsat B1   70.0W 166.6 178.6 38.1  -9.6
                 Nahuel 1 & AMC 6   72.0W 169.4 181.4 38.4  -7.6
                        DirecTV 5   72.5W 170.1 182.1 38.5  -7.1
                            SBS 6   74.0W 172.2 184.2 38.7  -5.6
                            AMC 5   79.0W 179.4 191.4 39.0  -0.5
                          Nimiq 2   82.0W 183.7 195.7 38.9   2.6
                            AMC 9   83.0W 185.1 197.1 38.9   3.6
                     Brasilsat B3   84.0W 186.5 198.5 38.8   4.7
                           AMC 16   85.0W 187.9 199.9 38.7   5.7
                            AMC 3   87.0W 190.8 202.8 38.4   7.7
              Intelsat Americas 8   89.0W 193.6 205.6 38.1   9.7
                 Galaxy 11/Nimiq1   91.0W 196.3 208.3 37.7  11.6
                     Brasilsat B4   92.0W 197.7 209.7 37.5  12.6
                        Telstar 6   93.0W 199.1 211.1 37.2  13.5
                        Galaxy 3C   95.0W 201.7 213.8 36.7  15.4
              Intelsat Americas 5   97.0W 204.4 216.4 36.0  17.2
                        Galaxy 4R   99.0W 207.0 219.0 35.4  19.0
                            AMC 4  101.0W 209.5 221.5 34.6  20.7
                            AMC 1  103.0W 212.0 224.0 33.8  22.3
                           AMC 15  105.0W 214.4 226.4 33.0  23.9
                          Anik F1  107.3W 217.1 229.1 31.9  25.6
         DirecTV 6 & EchoStar 6/8  110.0W 220.2 232.2 30.6  27.5
                          Anik F2  111.1W 221.5 233.5 30.0  28.3
                    Solidaridad 2  113.0W 223.5 235.6 29.0  29.6
                         SatMex 5  116.8W 227.6 239.6 27.0  31.9
          EchoStar 7 & DirecTV 7S  119.0W 229.8 241.8 25.7  33.2
  EchoStar 9/Intelsat Americas 13  121.0W 231.8 243.8 24.5  34.2
                       Galaxy 10R  123.0W 233.7 245.7 23.3  35.3
                        Galaxy 12  125.0W 235.6 247.6 22.0  36.2
             Galaxy 13/Horizons 1  127.0W 237.4 249.5 20.8  37.1
 Intelsat Americas 7 & EchoStar 5  129.0W 239.2 251.3 19.5  38.0
                           AMC 11  131.0W 241.0 253.0 18.2  38.8
                        Galaxy 1R  133.0W 242.7 254.8 16.9  39.5
                           AMC 10  135.0W 244.4 256.4 15.5  40.2
                            AMC 7  137.0W 246.1 258.1 14.2  40.9
                            AMC 8  139.0W 247.7 259.7 12.8  41.5
                     EchoStar 1/2  148.0W 254.7 266.7  6.5  43.7
coolsat 4000 pro question
This is getting frustrating! G10 quality LOW
