Cabling should go....
Receiver----->Motor----->"L" port on the LNB
lnb with l&c connecters...for cband and ku
Does it look like this...
Invacom QPH031 Ku Band Linear Circular LNB | Great for Galaxy 10R Galaxy 25 AMC 4 and others
If so, it's Ku only "C"ircular and "L"inear signals.
You first need to Lock your True South Sat, it's the Sat that is at the same Longitude as your location.
What is your location?
I can do manually on motor itself up on roof of course
In the receiver's setup menu, you need to set the Motor option to USALS and enter your Lat and Long. xx.xNorth and xx.x West (east is the default)
Other settings in your True South Sat setup menu:
LNB: Standard or Single
LNB Freq L.O.: 10750
Motor: USALS, in the sub-menu select Go to Ref, that should drive the motor to it's Zero point.
Transponder: You must have a Hot TP selected for the Quality Meter to light up.
With the motor at Zero, set the Motor's "Latitude" scale to your Lat (not the Elevation scale)
Where are you located / zip code?
