Next Tuesday I should have a new 522 in operation and I have some questions:
a - I assume that recorded shows become tuner independent. That is, from any TV I'll be able to select from a single list of recorded shows. True?
b - The major reason I selected the 522, is that I can record two shows at the same time. Can I set up the record schedule from one remote (remote equals one tuner I understand) and then let the software select the tuners to do the recordings (assumes I'm not watching anything; TV off or watching a prerecorded show) or, do I have to set up a recording schedule for each tuner myself (boo)?
c - If I want to use the PIP feature on my TV, does that put me in the "single user mode" camp? I think it does.
d - I currently have a 301; per the spec sheet for the 522, tuner one outputs appears to be identical to the 301. I have a slave TV in the kitchen (a cool undercounter dropdown Audiovox LCD) that is connected via a splitter inbetween the RF out/TV connection of the 301. I tried the 301 S-video/TV connection and the 301 RF/slave TV simultaneously but couldn't get a picture on the slave. Seems only one output is possible at a time (at least as I recall after fiddling with this two years ago). Anything in the 522 that would let me do PIP AND go to the slave TV from tuner 1 (don't want to pay for another 301 box or have room for one in the kitchen space)?
e - What is "agile modulation"? I did a search but couldn't find a definition about how is works. What do I have to do on the receiving TV end to use it?
f - The Digital Remote Control user guide provides a way to change the AUX setting. Could this be set so that the Control be used to address both tuners? I.e., remote 1 AUX w/b set to tuner 2 and remote 2 AUX w/b set to tuner 2. What would be the codes for setting the opposite tuner on each remote's AUX button?
g - I have an RF to UHF upgrade kit. I could use it for tuner 1 if the UHF signal is different from the UHF Pro antenna signal. Is it? If not, I have an IR extended cable that can be taped to the IR "eye" for tuner 1 on the box. Would that work?
h - The Digital Remote Control user guide provides a way to change the Remote Address (found on the Installation and Setup screen). Could this be used to eliminate any UHF conflict between the Upgrade kit and the UHF Pro remote controllers?
That's enough for now. Thanks in advance for any and all replies,
Regards, Mike
Regards, Mike
