Nice dish Gillham, you will find out that plays real good, will run with the 1.2m CM, or perform a little bit better not by much but it does when you start you're fine tuning. Have the same dish here that I fab on a old horizon motor mount. an they are old about the 1st time I have seen these models was early to mid 80's.
now on the feed legs that dish took 3-legs to a aluminum block, an the legs bolted to the to the dish 1 at bottom, 2 on the side, (should see 1/4" holess on the edges of the dish) an they where made out of metal pipe about 3/4" diameter. so they should be able to be made fairly easy, I can give you how long that they need to be, an also F/L. also the Channel Master feed support, (black plastic) will also work on that dish tried 1 but went back to its metal 1 gave me more adjustment.
will give you what I found on setting mine up here, used a laser pointer, dewalt zip tied to the end of a Channel Master ku feed, an if you will draw a line across in a X patern from its 4 mounting locations of where the mount gos that is where my laser shot to.
Hello from Normandy!
A friend of mine, radio amateur, gave me a satellite dish "Northern Satellite Corp. Model NSC12-1" this week.
I rescued the dish and all I have is the bracket mount, three feed legs and a Gardiner LNB.
I don't have any of the mount hardware and I have no idea of the way the three legs were attached to the disk and how the LNB was set to the legs. There are some missing parts like the feed support and the parts to fasten the feed legs to the dish.
I have to ask 1captain to give me some specs and measurements from his to start working on this rescue project: how long the legs need to be, how the legs are bolted to the dish and how to build the feed support.
Pictures will tell the tale best.
Many thanks,
Daniel
