June 26th, 2013
Minor Firmware Update is Available
GEOSATpro firmware GSPMHD_20130626 for USB Update and maincode 2013-6-26 for Satellite Update (via Galaxy 19, freq. 12115, PID 330)
Warning: The GSPMHD_20130626 / maincode date 2013-2-18 is a main system file and will overwrite all user settings and channel scans.
We strongly recommend users to perform a Factory Reset and Remove the Power Plug for 10 seconds to power cycle the STB after the firmware update is completed.
Important Clarification about loading .udf files created with previous firmware versions. We DO NOT recommend loading old User Database files (.udf) that were saved on previous firmware versions older than 0.13. While the saved .udf file may be fine and cause no operational issues, the file could contain data that will cause the microHD to enter a reboot cycle. Please follow our recommendation of rebuilding your channel list using the database file that is in this firmware.
You may safely load any User Data Base (.udf) file created and saved from a microHD operation on firmware version 0.13 or newer. If you have an older User Data Base created with firmware older than 0.13, use the attached new Satellite/ Transponder list. If you use a switch or motor, you will need reconfigure and re-enter your location Longitude and Latitude settings.
MicroHD Firmware Notes:
Date: 6/26/2013
Version: GSPMHD_20130626 / maincode dated 2013-6-26
Date: 6/26/2013
- Modified PID/SID Auto Update - Modified the PID/SID auto update function to prevent overwriting of existing program and service identifications.
- Corrected Motor Move - Motor movement is now continuous between two motor positions or calculations. GoTo X time is now set for 60 second timeout for correct positioning with some non-compliant DiSEqC 1.2 devices.
- Satellite List - Name Changes
