January 31st, 2013
Minor Firmware Update is Available for DVR Skip Interval and Dolby APID
GEOSATpro firmware GSPMHD_0.19_0131201 for USB Update and maincode 2013-1-31 for Satellite Update (via Galaxy 19, freq. 12115, PID 330)
Warning: The GSP_MHD_019 / maincode 2013-1-31 update is a main system file and will overwrite your settings and channel scans.
We strongly recommend users to perform a complete Factory Reset after the firmware update.
You may safely load any User Data Base (.udf) file created and saved from a microHD operation on firmware version 0.13 or newer. If you have an older User Data Base created with firmware older than 0.13, use the attached new Satellite/ Transponder list. If you use a switch or motor, you will need reconfigure and re-enter your location Longitude and Latitude settings.
Important Notice: Before updating the firmware, Please back-up your current firmware to an USB - Save to USB (ALLCODE) .abs in case it is needed to restore to previous version.
Important Clarification about loading .udf files created with previous firmware versions. We DO NOT recommend loading old User Database files (.udf) that were saved on previous firmware versions older than 0.13. While the saved .udf file may be fine and cause no operational issues, the file could contain data that will cause the microHD to enter a reboot cycle. Please follow our recommendation of rebuilding your channel list using the database file that is in this firmware.
MicroHD Firmware Notes:
Date: 1/31/2013
Version: GSPMHD_0.19_01312013 / maincode 2013-1-31
- After the .abs firmware file update is completed, power cycle the rmicroHD by removing and reinserting the power plug. Perform a Factory Reset before reconfiguring the satellite settings and scanning for channels or loading an .udf file.
Date: 1/31/2013
- Corrected: Dolby/AC3 APID Display
- Activated: Playback Interval Skip Function
