Well I had to replace my shorted out Norsat Ku lnb due to a damaged , by a gardener, dbc ribbon cable ..ouch ! Fortunately the receiver had short circuit protection.
I replaced it with a better specification NJRC 2744HH, but have a very poor (low) signal , especially those erratic RTV DVB-S2 signals on 87 W Lat. The main concern I have is that the new lnb has it's antenna probe offset from the center where I expected it to be. It's in the upper left quadrant. I mounted in several orientations with no difference. The only other changes were replacing an aging and broken servo motor on my Chapparal with an international model. Yes I know about the dieltric losses on C-band, but I was re-assured by Duke Fishman at Chaparral that the dielectric does not affect Ku signals at all - C-band loss is only 1 db they claim, but many argue that it's closer to 3 db or more. The sytem was peaked over a 2 1/2 month period to track from Pas9 (58') actually 55.5 W, and 137 W or AMC-7 with 24' Von Weise.
My dish is a SAMI 10 ft mesh in pretty good shape. For example at 83 W , AMC-9, Luken channels are very weak, but the AMC9 network feed has a strong signal at 70 on my microHD Pro, and only 20-35 on the RTV feeds - yes I know about the poor reception of those signals - btw try 137 for the west RTV feeds, they are much more stable and strong at least at my location despite the low elevation and terrestrial noise.
I like having the Ku as well to peak my dish with, fine tune my C-band alignment. One other concern I have is the servo motor (new). I can't get it to be perfectly vertical or horizontal but it's off by some 30 degrees or so, which I compensate in the skew settings in my Startrak 400 (H=030, V=120, instead of the h=000,v=090).
I took it off and looked at the probe so I can visually confirm this. How can I get it back to straight up and down and across ? Have the gears gone out of alignment inside ? I tried gently to 'help' it by turning the black disk but that didn't do anything.
Sorry about all the questions but I'm anxious to get everything working satifactory before the harsh winter hits - in two weeks !
TvMind
TvMind
