So I decided to make the switch from Directv to Dish and had my install today. I had a Hopper w Sling, Super Joey, and regular Joey installed. Install seemed to go smoothly and when it was done I had to leave right away to get back to work. When I get home from work I go to turn on the TV that has the Super Joey connected to it and it is stuck at the receiver setup wizard screen. Says that the receiver needs to be activated. So I call Dish. They have me try a few things and then tell me that they will have to send out a tech and the soonest they can send one is May 26th!! Needless to say not happy about that. So I've been working with JasonS trying to figure out what the problem is and see if I can fix it myself before the tech comes so I can get up and running.
I only had 2 coax lines coming into the house so here's how the installer did it. She put the dish on the roof. That has 3 coax lines coming off of it. She ran 2 into the solo node and 1 into an integrator. Then the integrator is connected to the client line on the solo node and the other end of the integrator goes directly to my Super Joey. Off the host line of the solo node it runs into my basement where she installed a tap. One end of the tap goes to the Hopper and one end goes to the regular Joey in my kitchen. When I check the MoCa network everything checks out and the Hopper recognizes both Joey's and recognizes one as a Super Joey. If I push the red button it says there are 5 tuners, but tuner 4 and 5 just say acquiring data. If I do a check switch it fails. Tuners 4 and 5 just sit at 1 of 1. I tried eliminating the tap and the regular Joey thinking that was the problem and it didn't change anything. Someone please help! I'm not angry about things not working cause it happens. I'm just extremely mad that they can't send out a tech for a month!! I think that's ridiculous on a new install.
JasonS is doing his best to try and help but there's a shortage of techs in my area. Just thought I would see if you guys have any other ideas.
