Scottc98 (Like that name
Scott.......)
Is trying to hook up just one receiver right now and plans to add a PC DVB card in the NEAR future!
Good Idea to keep all your posts about your setup here, makes life easier for everyone!
The Invacom QPH-031 will work with just two receivers for both C and L.
I use the same LNBF (QPH-031) and I use just one L and one C output, they go to a 2 way DiSEqC switch then its all set up on the receiver "Port one for Linear satellites and port two for the Circular satellites". You could do the same with two 2 way switch for one receiver or with a 4 way DiSEqC switch.
Remember each side of the LNBB has to have the correct L.O. set in the antenna setup screen!
L.O. Linear side = 10750
L.O. Circular side = 11250
AMC-9 is your true south, there are LOADS of Mardi Gras feeds there right now! best to ask just before you hit the roof and someone will give you a live TP. to use for pointing!
We do not mention channels or feeds that are not listed on Lyngsat here, thats the BEST way to lose FTA channels
Code:
Hilliard, OH 43026
Latitude 40° 1.932'N Longitude 83° 8.298'W
Sat Name Sat Lng Az(t) Az(m) El Skew
Telstar 12 15.0W 104.5 111.6 7.9 -47.9
Intelsat 901 18.0W 106.6 113.7 10.2 -47.2
NSS 7 22.0W 109.5 116.6 13.2 -46.2
Intelsat 905 24.5W 111.4 118.5 15.1 -45.5
Intelsat 907 27.5W 113.7 120.8 17.3 -44.5
Hispasat 1C/D 30.0W 115.7 122.8 19.1 -43.6
Intelsat 801 31.5W 117.0 124.1 20.2 -43.0
Intelsat 903 34.5W 119.5 126.6 22.4 -41.8
AMC 12/T 11 37.5W 122.2 129.3 24.5 -40.4
NSS 806 40.5W 124.9 132.0 26.5 -38.9
Pas 3R/6B 43.0W 127.3 134.4 28.2 -37.5
Pas 1R 45.0W 129.3 136.4 29.5 -36.3
Intelsat 705 50.0W 134.6 141.7 32.6 -33.1
Intelsat 707 53.0W 137.9 145.0 34.3 -30.9
Intelsat 805 55.5W 140.9 147.9 35.7 -28.9
Pas 9 58.0W 143.9 151.0 36.9 -26.8
Amazonas 61.0W 147.7 154.8 38.4 -24.2
EchoStar 3 61.5W 148.3 155.4 38.6 -23.7
Rainbow 1 61.5W 148.3 155.4 38.6 -23.7
Estrela do Sul 1 63.0W 150.3 157.4 39.2 -22.3
Brasilsat B2 65.0W 153.0 160.1 40.0 -20.3
Brasilsat B1 70.0W 160.1 167.1 41.7 -15.1
Nahuel 1 71.8W 162.7 169.8 42.2 -13.2
DirecTV 1 72.5W 163.7 170.8 42.4 -12.4
AMC 6 72.0W 163.0 170.1 42.3 -13.0
SBS 6 74.0W 166.0 173.1 42.7 -10.7
Echostar 4 77.0W 170.5 177.6 43.3 -7.3
AMC 5 79.0W 173.6 180.7 43.5 -4.9
Nimiq 2 82.0W 178.2 185.3 43.7 -1.4
AMC-9 83.0W 179.8 186.9 43.7 -0.2
Brasilsat B3 84.0W 181.3 188.4 43.7 1.0
AMC 2 85.0W 182.9 190.0 43.6 2.2
AMC 3 87.0W 186.0 193.1 43.5 4.6
IA-8 89.0W 189.1 196.2 43.3 6.9
Galaxy 11 91.0W 192.1 199.2 43.0 9.2
Nimiq 1/3 91.0W 192.1 199.2 43.0 9.2
Brasilsat B4 92.0W 193.6 200.7 42.8 10.4
Telstar 6 93.0W 195.1 202.2 42.6 11.5
Galaxy 3C 95.0W 198.1 205.2 42.1 13.7
Telstar 5 97.0W 201.0 208.1 41.5 15.9
Galaxy 4R 99.0W 203.8 210.9 40.9 18.0
Spaceway 2 99.2W 204.1 211.2 40.8 18.2
DirecTV 1R/4S/8 101.0W 206.6 213.7 40.1 20.1
AMC 4 101.0W 206.6 213.7 40.1 20.1
Spaceway 1 102.0W 208.0 215.1 39.8 21.0
AMC 1 103.0W 209.3 216.4 39.3 22.0
AMC 15 105.0W 212.0 219.0 38.5 23.9
Anik F1/R 107.3W 214.9 222.0 37.4 26.0
DirecTV 5 109.5W 217.6 224.7 36.3 27.9
EchoStar 6 110.0W 218.2 225.3 36.1 28.3
EchoStar 8 110.0W 218.2 225.3 36.1 28.3
Anik F2 111.1W 219.5 226.6 35.5 29.2
Solidaridad 2 113.0W 221.8 228.8 34.4 30.7
SatMex 5 116.8W 226.0 233.1 32.2 33.4
DirecTV 7s 119.0W 228.3 235.4 30.9 34.9
EchoStar 7 119.0W 228.3 235.4 30.9 34.9
EchoStar 9/Telstar 13 121.0W 230.4 237.5 29.6 36.2
Galaxy 10R 123.0W 232.4 239.5 28.3 37.3
Galaxy 14 125.0W 234.3 241.4 27.0 38.5
Galaxy 13/H 1 127.0W 236.2 243.3 25.7 39.5
Intelsat Americas 7/Echostar 5 129.0W 238.0 245.1 24.3 40.5
AMC 11 131.0W 239.8 246.9 22.9 41.4
Galaxy 1R/15 133.0W 241.5 248.6 21.5 42.3
AMC 10 135.0W 243.2 250.3 20.1 43.1
AMC 7 137.0W 244.8 251.9 18.6 43.9
AMC 8 139.0W 246.4 253.5 17.1 44.6
EchoStar 1 148.0W 253.2 260.3 10.4 47.1
EchoStar 2 148.0W 253.2 260.3 10.4 47.1
Satellite Finder is (c) Copyright 2004, P. Lutus
I know you do not want to be on the roof all day........
I suggest you do not use any motor or switch to start with and find and store your true south satellite first, only then add the motor and any switch.
In the long run it may save you some time!
