I finally upgraded this week to the Hopper w/ Sling from the Hopper 2000.... The DISH techs onsite downloaded the new Carbon UI to all my new receivers (2 Hoppers w/ Sling, 4 Joeys 2.0) .... I did not want the Hopper 3 after reading here about all the OTA issues it was having with the Joeys....
However, the OTA issues on the new Carbon UI are also serious, whereas I had no OTA issues under the old UI...
1) If you try to do a new OTA scan and the first OTA channel (originally scanned) listed is "not locked", the receiver will shut down and re-boot.... Has happened over 10 times in a row !!!...
Only when the first OTA channel is "locked" will the receiver then proceed to scan again.... Confirmed it on the 2 Hoppers w/ Sling, so it's not a receiver issue, it must be a software issue with the new carbon UI, right ?
2) The "info" screen on OTA channels is missing the OTA antenna's "Signal Strength" meter reading..... The only way to know your signal strength now is to go back into the OTA menu section, look for the OTA channel in the long list of scanned channels, and select it there.... But, again, if the first channel on that list is "not locked", the receiver will shut down and re-boot over and over again.... So now it's almost impossible to know your antenna strength numbers unless you put yourself through this agony...
3) The OTA scanned channels inside the menu's scanned list has a programming mistake..... The channels will appear out of order because instead of starting at channel 02, 03, 04, etc., it starts at Channel 10.... So if you have a local channel 2 it will get inserted in-between 10 and 30; Channel 4, between 30 and 50; Channel 6, between 50 and 70, and so on....It has nothing to do with their RF frequencies, it's their virtual numbers that are out of order....
4) And, hard to believe, but DISH in this new UI got rid altogether of the RF frequency input option, as we had available for years, and which they had been promising, in the original Hopper UI, as "this feature coming soon." HA !!!
Can others here confirm my conclusions above ? Or did I get some things wrong ??? Thanks !!!
