Well, that was disappointing. I replaced my current universal LNB with the new Avenger LNB I've been waiting for to arrive in the mail. It finally arrived. I have a good idea of what each satellite's signal should be (even based on time of day / type of weather) and my first impressions of the Avenger were positive. Stable signals, signal quality as high or higher than I expected on each satellite as I swung the motor across the arc.
Suddenly, without warning, I had no signals from any satellite. It was as though somebody had disconnected the cable from the LNB. I went to check the LNB and noticed, probably due to the motor moving, the RG-6 connector had come a little loose. I tightened the connector and put away my tools/ladder so confident I had found the problem. Still no signals.
After monkeying for a while, I ran out of light and had to give up for today. End result is no signals from the Avenger. I did connect my Shaw Direct dish to my FTA receiver and have verified the receiver is fine.
Tomorrow, I will swap my old LNB back in to see if all is OK with that one. I have no switches; my RG-6 runs from my receiver to my motor, and from the motor directly to the LNB.
What happened? Is this Chinese quality control? Did the loosened connector connect/disconnect the voltage several times causing a failure? It was all looking so promising at first try. I had even scanned in MICROHD on 103W which I haven't seen in months since my tree leaves started growing.
