New 9200HD problems
transco
78
My 9200HD arrived this afternoon and already I'm having trouble. I also have a 3500 that I've used with the same motor driven antenna and it worked perfectly... in less than an hour I had 15 satellites setup. I've messed with the 9200 for several hours and so far only have G25 working. One strange thing I've noticed is the Signal Strength and Quality readings are very unstable. Regardless of the satellite, they keep dropping to zero, then back up, then back to zero again. I'm using USALS positioning for the antenna which works great on the 3500 (yes I remembered to set my Lat / Lon on the 9200). Any ideas what could be happening? In theory the receiver was fully tested before shipment. It came equipped with the DVB-S2 8PSK board installed.
sats. 110 & 119
3_sat setuP
