I just upgraded my 625Duo DVR to a 722 HD DVR 2 days ago.
When the unit is first powered on, the TV2 UHF remote works fine, changing all the channels, guide, etc... if you let the remote sit for 3-4 minutes, it stops changing anything on Dish.
It still controls the volume, TV power, mute, but none of the satellite functions work.
Everything I've tried:
If I reset the 722 DVR, it works again for approximately 3 minutes and stops working again. If I go to the System Information screen and go through the setup steps, the remote starts working once again, but only for 3-4 minutes before stopping again.
I've made sure the DVR is and stays in dual mode.
I've tried all 15 remote channels for TV2.
I've tried changing out the batteries, plus I have 2 TV2 remotes anyway and they both stop working at the same time (rules out the remote being the problem).
I've tried boosting the UHF signal using the boost method I've seen mentioned on this forum. I've tried extending the antenna, but then again, it doesn't matter if I'm standing right next to the DVR or in the other room. Once it stops working it doesn't matter where I am. (rules out the UHF antenna not being positioned correctly or the range being too far).
It doesn't matter if the LCD TV in the front above the DVR is on or off or if any of the other components in the entertainment console are on or off (rules out UHF/electronic interferance).
Anyone ever encounter something similar to this or know of a fix? Seems odd that it works absolutely fine right after power up and then "poof" it goes away once it has been idle for 3-4 minutes.
I'm thinking the UHF receiver in the 722 DVR is bad or something is odd in a software setting somewhere telling the UHF receiver to shut off after an amount of time.
