Okay I've been going through this forum and Dbstalk's forums about the 522 and I have a couple of questions that I'm not clear on. Sorry for the long post. Hopefully I won't ramble too much ;-)
1st: My Current setup is 1 508, 1 501 and 1 301. I have a Quad LNB. Once the 522 shows up I am going to retire the 301. So my first question has to do with what "ports" on the Quad LNB should go to what. I read a couple of posts here and the consensus seemed to be that you hooked up ports 1&2 to the 522, is that correct? And which are 1&2? If I'm holding the LNB looking at the ports is it 1234 left to right or 4321 left to right?
2nd: I will only be using the 522 in single mode i.e. just driving 1 TV. I am going to make some statements here, please let me know if I'm wrong. I can watch 1 channel and record another. I can pause 1 channel switch to the other come back within 60 mins and the previous channel will still be paused. I can watch 2 different channels at the same time using PIP (No audio in the PIP window). I can record 2 different channels at the same time while I'm watching something I have recorded from before. I can do this all with the UHF remote.
3rd: When I setup a timer to record can I pick the tuner it uses?
Until I actually get it I think that's it. I appreciate your patience those that have made it this far ;-)
Tack (Swedish for Thanks),
Kevin
Kevin
