After my nightly reboot the Netflix app on my Family Room Hopper3 will have the wrong IP address 169.254.120.96 even though the Family Room Hopper3 has the correct IP address of 192.168.1.21.
When this happens the Netflix servers 1,2,3, and 4 will all have X showing they are not connected. Although Netflix still works for 1080i content it will not do any 4K content.
The solution is to reset the Family Room Hopper3 network. The Netflix app will then have the correct IP address of 192.168.1.21. All 4 Netflix servers will show a green check mark and 4K content will play.
My router is hard wire connected to my Living Room Hopper3 and my Family Room Hopper3 uses a moca connection for internet. I do this because Dish told me that I should only have 1 gateway connection. My assumption is that during the nightly reboot the Family Room Hopper3 tries to connect before the Living Room Hopper3 is finished connecting. I am guessing that the 169.254.120.96 address is a moca address. When I reset the network on the Family Room Hopper3 it then uses the correct IP address of 192.168.1.21 and everything works correctly. What baffles me is that Netflix has the incorrect IP address while the Hopper3 has the correct IP address.
Anybody having trouble watching 4K Netflix content on their Hopper3 should check the Network settings in the Netflix app. Go to settings (gear), and select “Check your Network”. I have found that anytime the IP address shows up as 169.254.xxx.xx I will not show connections to the 4 Netflix servers and I am not able to watch any 4K content. On the other hand, I have found that anytime I am able to see all 4 Netflix servers I can play 4K content.
