I'm hoping that someone here can shed a little technical know-how here.
I am in the middle of having an 811 receiver added to my home. I currently have 3 301 receiver and 1 6000 receiver. These are connected to two dishes via a single sw64.
A DishNetwork installer came out to my home to add the 811 receiver. He made 6 splitter assemblies and ran a new cable to the designated location before he realized that he did not have the SW64 in his truck. An install has been rescheduled for this Sunday.
Today I was surfing the Internet and wanted to see what an SW64 retails for. One hit from Goggle was a pdf file on dishnetwork.com http://www.dishnetwork.com/downloads/pdf/technology/installation/install-5.pdf
Well the installation shown on the dishnetwork site is not what this installer is going to do. Should I be concerned?
On the website, there are six splitters. Each splitter has two ports. One port is a DC Pass Port and the other port is a DC Block Port. The DC Pass Ports all go to the primary SW64. The DC Block Ports make their way to the Secondary SW64. In addition, for each Dual LNB, one of the DC Block Ports is connected to a Feed-through load. Can someone tell me how this works? Is the use of DC Blocked Ports necessary? What happens if...
The installer at my home is not using Feed-through loads AND each splitter is labelled:
25-HFS22DN
5-2300MHz
2-WAY SPLITTER - 100dB RFI
ALL PORTS POWER PASS
DIODE PROTECTED
I have the feeling that this is not correct. If this is not going to work, then I will call the installer's dispatch center and try to make sure that whoever shows up to install the SW64 has the correct equipment.
25-HFS22DN
5-2300MHz
DIODE PROTECTED
