Need some one to check my work
Long Hair
377
57
Mo
I have a unimesh dish 7.5ft, I'm trying to find out my F/d ratio. Here is what I have
7.5 x 12 = 90inches diameter of the dish, 13.5inches depth in inches 90x90=8100, 16x13.5=216. 8100/216=37.5inches 37.5/90=0.416666. If this is right how do I set the F/D to 37.5 when I'm maxed out at 36inches. Any info would help. The reason I'm asking is because some tp's don't come in on my 4dtv box. example on g1 @ 133west I get stars mux but not HBO.
Sounds like you are confusing focal length with F/d ratio.
F/d ratio is the measurement of the depth of your feedhorn in the scalar ring. Depending on what type/brand of feed you have you may see some numbers and lines on the tube that sticks into the scalar ring? That is where you set your F/d ratio.
The focal length is the distance from the flat of the center of your dish to (I think) about 1/4" into the mouth of your feedhorn.
If I recall correctly the Unimesh 7.5 has an f/d ratio of .40 so that would be the scalar ring setting and the focal distance is 36" to about 1/4" into the feedhorn throat.
If there is no .40 tick mark like on the Chaparral feed then yes, measure .20" (1/5") up from the feed throat to the bottom of the scalar ring.
Coolsat 6000 Premium 101w
Help!!!!! Need FTA Church Channel in Ohio
