Hi. I'm a dishnetwork user needing help with my installation at a permanent campground site. I originally had a Dishnet 500 quad hooked to a standard def receiver running 200ft of cable to access clearing for dish. I only needed to run one cable and system worked fine.
Upgraded to a vip211k hi-def reciever. Added a second dish pointing to 61.5. (able to get to satellite from my lot using only 20ft of cable). Inputed both the dish 500 line and the 61.5 line into a sw-21 to run to 211 reciever. Worked fine!. but can only use one reciever.
Want to add a second vip211 reciever so purchased a dpp 33 switch to output to both tv's. When I inputed the 500 line and the 61.5 line into the dp33, I was only able to see sats 110 and 61.5. What would I have to do to get the 119 sat input. Is there anyway I can get both 110 and 119 to the dpp33 from the Dish 500? I would prefer not to have to run a second cable through 200 ft of wooded area unless absolutely necessary. Thanks for the help!
