This is sort of a long story, so please bear with me.....
Up 'till now, I've had a Dish 500 legacy twin, with the two feeds routed directly to a 301 and a 6000. Back in January, in anticipation of buying a 921, I ordered a DP-34 and a DP Twin, so that I could have four feeds from the 500 (301, 6000 with legacy adaptor, 921x2). I never hooked the new equipment up until this weekend (after having bought a......ahem......$839 921!). I still haven't activated the 921 (and may not after today's news), mostly because of the way the 301 is behaving.
A "check switch" shows everything to be OK, but if you go to the "Point Dish" screen, many transponders are showing "0" signal. If you throw out the spot beams and HD transponders, it boils down to these:
119 transponders 2, 4, 6, 8, 10, 12, 14, and 16.
110 transponders 12, 14, and 16.
The one thing these all have in common is left-hand polarity, although some TP's with left-hand polarity on each sat are working fine.
I called Dish Tech Support, and they had me hook up direct to the LNB (bypassing the DP-34) to rule out the switch as the problem. I did this, using both sides of the LNB, and had the same results, except I did get a signal on a couple of spot beams I couldn't get with the switch. At that point they were ready to blame the LNB. I asked them if this LNB (CCS9601, Lot # G211) was in the bad batch I'd heard about; they said no, and that my only recourse was to try to get it exchanged by the retailer (Dishstore.net).
Now, here comes the kicker. I then hooked up the 6000 and Legacy adaptor through the DP-34, and it worked absolutely perfectly - every TP got a good, strong signal!
I'm beginning to think that maybe the 301 is bad, but it was working fine with the legacy Twin. One thing I didn't try, and probably should have, is a power cord reboot. I will try that after I remount my dish on Friday (I'm coincidentally having some stucco work done this week, and took it down last night).
Anybody have any ideas?
Brad
Brad
