I was on Directv about 2 or 3 years ago and left for fios and were moving and I can't get fios any more. I have 2 receivers H 20- 600 Can you still use the receivers with Directv now.
Yep, if you come back they will give you new, much better ones.
Yes, you can use those boxes.
But IMHO those recievers h20-600 are junk. recalled for heat issues.
I would recommend getting new boxes if i were in your shoes.
Many of the early models of the H20-600 had heat related issues, but once they fixed the problem, they were very reliable. I went through three of them before I got a good one. I have had it over two years with no issues.
If they worked the last time you used them I'd keep on using them when you resubscribe to DIRECTV. If for some reason someone from DIRECTV tells you that you can't use them tell them they better provide replacements for free.
Why would they replace them. They are not leased, unless he has the protection plan they are not covered.
Either way, by resubscribing, the op is committing to a two year contract. He might as well get the best come back deal you can and get new equipment. The current receivers, especially the 24 series receivers are light years ahead of those.
