need help
deddy
Not sure if this is the right place for my question if not I am very sorry. But
moving on I need help I just put together my motorized dish and I am at the point of wiring up my motor to the Lnb and to the 4 way DiSEqc Switch and to my 2 receivers I have no clue how it should go can some one help? I have a powertech DG-240 motor and a Quad polar Legacy 4 O/P LNB and a diseqc switch 4 x 1 (S-DS41C model) and two Captiveworks 600s Premium recievers.
You would do better with a 4x4 multi-switch.
With a diseqc switch it goes like this:
lnbf L side (either L port) to diseqc port 1
lnbf C side (either C port) to diseqc port 2
diseqc output to DG240 motor
DG240 motor to Receiver
Receiver loop-out to other Receiver
Note: this way second receiver gets only channels on same polarity and sat as first receiver
Hope this helps...!
Or, if you used a multi-switch it would go like this:
lnbf L port to V input of multi-switch
lnbf L port to H input of multi-switch
lnbf C port to 22khz V input of multi-switch
lnbf C port to 22khz H input of multi-switch
multi-switch output to DG240 motor
DG240 motor to Receiver #1
multi-switch output to Receiver #2
Buzz 2010F Updated FACTORY Firmware??
G26 Question
