Need help setting up
ladila2
Hi, I am new at this. Trying to setup my fta dish, etc. Need help on confirming settings on installation...have a invacom quad lnb, diseqc 1.2 motor and coolsat 6000 receiver. My zipcode is 32162 (Florida). Presently, I can't get any signal. Can anyone out there help? Thanks, ladila
WELCOME to the SatelliteGuys.US FTA forum, I would just use a Linear output of the LNBF for now without any switch. Make sure the L.O. (LNB Freq.) is at 10750
Here are all the angles to the satellites from your area.
Code:
Lady Lake, FL.
         Latitude 28° 55.794'N Longitude 81° 55.536'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W  95.9 101.3  1.9 -60.5
                Atlantic Bird 3    5.0W  96.4 101.8  2.7 -60.4
                Nilesat 101/102    7.0W  97.4 102.9  4.5 -60.2
     Telecom 2D/Atlantic Bird 2    8.0W  97.9 103.4  5.4 -60.1
                     Express A3   11.0W  99.5 104.9  8.0 -59.7
                 (C) Express A4   14.0W 101.1 106.5 10.7 -59.2
                     Telstar 12   15.0W 101.6 107.1 11.5 -59.0
                   Intelsat 901   18.0W 103.3 108.8 14.2 -58.4
                          NSS 7   22.0W 105.6 111.1 17.7 -57.4
                   Intelsat 905   24.5W 107.2 112.6 19.9 -56.7
                   Intelsat 907   27.5W 109.1 114.5 22.6 -55.8
                  Hispasat 1C/D   30.0W 110.8 116.2 24.8 -54.9
                   Intelsat 801   31.5W 111.8 117.2 26.1 -54.4
                   Intelsat 903   34.5W 114.0 119.4 28.7 -53.1
                     (C) AMC 12   37.5W 116.3 121.7 31.3 -51.7
                        NSS 806   40.5W 118.7 124.2 33.8 -50.1
                      Pas 3R/6B   43.0W 120.9 126.4 35.9 -48.7
                         Pas 1R   45.0W 122.8 128.2 37.5 -47.4
               (C) Intelsat 705   50.0W 127.8 133.3 41.5 -43.7
                   Intelsat 707   53.0W 131.2 136.6 43.7 -41.2
               (C) Intelsat 805   55.5W 134.2 139.7 45.5 -38.8
                          Pas 9   58.0W 137.5 142.9 47.2 -36.3
                       Amazonas   61.0W 141.7 147.1 49.2 -32.9
                     EchoStar 3   61.5W 142.4 147.8 49.5 -32.3
                      Rainbow 1   61.5W 142.4 147.8 49.5 -32.3
               Estrela do Sul 1   63.0W 144.7 150.1 50.3 -30.4
               (C) Brasilsat B2   65.0W 147.8 153.3 51.4 -27.8
               (C) Brasilsat B1   70.0W 156.4 161.9 53.8 -20.5
                       Nahuel 1   72.0W 160.1 165.6 54.5 -17.3
                      DirecTV 1   72.5W 161.1 166.5 54.7 -16.5
                          AMC 6   72.0W 160.1 165.6 54.5 -17.3
                          SBS 6   74.0W 163.9 169.4 55.1 -14.0
                 Echostar/G4R 4   77.0W 169.9 175.3 55.8  -8.8
                          AMC 5   79.0W 174.0 179.4 56.1  -5.3
                      Nimiq 2/3   82.0W 180.2 185.6 56.2   0.1
                          AMC-9   83.0W 182.2 187.7 56.2   1.9
                (C)Brasilsat B3   84.0W 184.3 189.7 56.2   3.7
                          AMC 2   85.0W 186.3 191.8 56.1   5.5
                          AMC 3   87.0W 190.4 195.8 55.8   9.1
                           IA-8   89.0W 194.4 199.8 55.4  12.6
                      Galaxy 11   91.0W 198.3 203.7 54.8  15.9
                     Nimiq 1/4i   91.0W 198.3 203.7 54.8  15.9
                (C)Brasilsat B4   92.0W 200.2 205.6 54.5  17.6
                           IA-6   93.0W 202.0 207.5 54.1  19.2
                      Galaxy 3C   95.0W 205.6 211.1 53.3  22.3
                           IA-5   97.0W 209.1 214.5 52.4  25.2
                      Galaxy 16   99.0W 212.4 217.9 51.4  28.0
                     Spaceway 2   99.2W 212.7 218.2 51.3  28.2
                DirecTV 1R/4S/8  101.0W 215.6 221.0 50.3  30.6
                          AMC 4  101.0W 215.6 221.0 50.3  30.6
                     Spaceway 1  103.0W 218.5 224.0 49.1  33.0
                          AMC 1  103.0W 218.5 224.0 49.1  33.0
                         AMC 15  105.0W 221.4 226.8 47.8  35.3
                       Anik F1R  107.3W 224.4 229.9 46.3  37.8
                     (C) AnikF1  107.3W 224.4 229.9 46.3  37.8
                      DirecTV 5  109.5W 227.2 232.6 44.7  39.9
                  EchoStar 8/10  110.0W 227.8 233.2 44.3  40.4
                        Anik F2  111.1W 229.1 234.5 43.5  41.4
                       SatMex 6  113.0W 231.2 236.7 42.1  43.0
                  Solidaridad 2  114.9W 233.3 238.7 40.7  44.6
                       SatMex 5  116.8W 235.2 240.7 39.2  46.0
                         AMC-16  119.0W 237.4 242.8 37.4  47.5
                     DirecTV 7s  119.0W 237.4 242.8 37.4  47.5
                     EchoStar 7  119.0W 237.4 242.8 37.4  47.5
          EchoStar 9/Telstar 13  121.0W 239.2 244.7 35.7  48.8
                     Galaxy 10R  123.0W 241.0 246.4 34.1  49.9
                  (C) Galaxy 14  125.0W 242.6 248.1 32.4  51.0
                   Galaxy 13/H1  127.0W 244.2 249.7 30.7  52.0
 Intelsat Americas 7/Echostar 5  129.0W 245.8 251.2 29.0  53.0
                     (C) AMC 11  131.0W 247.2 252.7 27.3  53.8
                  (C) Galaxy 15  133.0W 248.7 254.1 25.5  54.6
                     (C) AMC 10  135.0W 250.0 255.5 23.8  55.3
                      (C) AMC 7  137.0W 251.3 256.8 22.0  56.0
                      (C) AMC 8  139.0W 252.6 258.0 20.2  56.6
                   EchoStar 1/2  148.0W 257.9 263.3 12.3  58.8
       Satellite Finder is (c) Copyright 2004, P. Lutus
Your "true south" (TS) satellite appears to be Nimiq 2 (82 west). TS is the satellite that you use to properly set up a motorized dish. Once you've got that established, the motor will take of the rest of the satellites in the sky.
But... it's probably a better idea to simply mount only the dish on a mast so you get a feeling of where to manually aim the dish.
Nimiq 2 is a DBS satellite and you'll need a circular LNB to properly get a signal. Fortunately the QPH-031 has a circular output so it's a matter of hooking you receiver to the "C" port, selecting Nimiq 2 in your receiver and start aiming away!
First thing is to look at PSB's list and set your dish's elevation to what is listed for Nimiq 2 and using an active transponder, aim your dish more or less due south of your location. Make small, incremental adjustments in azimuth (left or right) and elevation (up or down) until you get a signal.
Unfortunately, some of the transponders on 82 are beamed more towards Canada so you may not get a signal on some of them down in Florida.
mrweather, thank you ever so much...I'll try to get started with your instructions...
Also let us know what brand of motor you have! That matters :)
Grrr, Remote Control Overlap!
KAMT on G10R -Q? about movies
