Need help, changing out receivers...
migold
557
71
Pearisburg, Virginia
I have a Pansat 9200HD, set up with 90cm dish on a DG380 motor. It is tracking the arc successfully. Now, I have an AZBox Premium Plus to install in place of the Pansat. I do not anticipate any problems, except I am not sure how to handle the motor position when I do the change. Should I set the motor on a particular satellite or the true south position, when I do the change over?
Thanks!
with some motors its also best to do a reset at the motor (SG2100's require the paperclip reset). But it varies.
Thanks, Iceberg! I have the AZBOX tracking 61w to 125w with no problem. I set the dish on my true south, changed receivers and everything went smoothly.
Thanks AGAIN!
advertize
Motor on Channel Master Elliptical Dish
