Hello Everyone,
I have a question about receivers.
I am on a very limited income,so I need to find a cheap,but good backup receiver.
I found and bought a coolsat 6000 Premium for about 56 dollars.
Now I think it was from a reputable dealer on flea bay,but who knows right?
It may be a clone or something and I have read that these units can just die out of the blue for no reason.The box looks legit, and so does the receiver.
It is suppose to be brand new not refurbished and from a reputable flea bay dealer with great feed back.
What I want to do is buy a backup just in case. I see most people on here have two or more receivers they are using. I can not afford these higher price models at this point as I am just getting started and still need a lot of stuff.
I can spend another 50+ bucks at most on a back up receiver.
I have found two possibilities on flea bay.
I can not decide which one to purchase.
I was wondering what you guys think about it.
I do not know anything about either of them and I am a total beginner to FTA.
My set up will be a bud and a prime star dish with a motor for FTA only on both.
Legal FTA nothing else.
Bud will have BSC621-2 C band and KU band LNBF.
Prime star I am not sure about yet?
These are the two receivers I am looking at.
BRAND NEW DIGIWAVE DG7200
Digiwave free to air receiver
with smart card slot
Compatible with DG7000 software and tools.
High Quality FTA Receiver.
Full EPG---7 days EPG
2mb Flash Rom for Fast GUI, channel changing and satellite
search
MultiSat Search
S-Video Out
Optical Audio Output
Easy-to-use Interface
4000 Channels Programmable
Fast Channel Scan & Change
Picture in Graphics (PIG) support
Conax CA-7 Embedded
General Features
EPG (Electronic Program Guide)
Full Compliant of MPEG-2 Digital & DVB broadcasting
950 - 2,150 MHz input Frequency (IF Loop Throughout)
Variable Input Symbol Rate (1-45 Msps)
Multi Language OSD (11)
Automatic PAL/NTSC Conversion
Fast Channel Change
4,000 Channels TV & Radio Program
Flexible reception of SCPC & MCPC from C/Ku-Band
Satellites
S/PDIF (Digital Audio or Dolby AC3 Stream out)
Timer Function (Automatic Turn On/Off by Setting Function)
256 Colors (Graphic User Interface) Number
PIG (Picutre in Graphic)
5 Favorite List & Unlimited Programs per each
Powerful Channel Editing Function
Sorting: Alphabetic, Satellite, FTA/Scramble, Parental
Lock
Move, Delete, Favorite Edit
Parental Lock, Channel Rename, Channel Skip
Manual PID / Satellite & TP / Network Scan
Smart Search
Satellite Scan - Receiver Simultaneous Scan with 4
Satellites
DiSEqC 1.2 and 1.3 Control Compatible (STAB USALS)
Capable of Setting the Frequency for SMATV System
Software Upgrade via RS-232C (Receiver to Receiver, PC to
receiver)
Going For 30-95 dollars+shipping on flea bay at the moment.
I can get it for 51.98 total.
Pros are it has been around for a while so people are familiar with it.
I should be able to get help with it if I need to right?
Help with set up and trouble shooting problems.
Cons are it is a very old model right?
Quality is not great but may be ok for FTA and a beginner?
The other one is a much newer model.
Xrica X-5 FTA RECEIVER
FASTEST SCAN EXCELLENT PICTURE QUALITY UP TO 9 DAY EPG
THIS IS A HIGH QUALITY RECEIVER MADE IN KOREA, NOT CHINA
TECHNICAL SPECIFICATIONS
Sampling frequency rate1. POWER SUPPLY
Type S.M.P.S
Input Voltage 100 – 240V AC @ 50Hz/60Hz±5%
Fuse Rating 250V/T2A
Nominal Power Consumption 27W
TUNER
Input Frequency 950 ~ 2150 Mhz
Input Signal Level -65 ~ -25dBm
Input Impedance 75 Ohm Unbalanced
Connector type 2 x F-Type, 3/8-32UNEF-2A (1 Input / 1 Loop through)
LNB power Supply 13V / 18V, max.750mA
22KHz Tone Frequency 22 ± 2KHz, Amplitude 0.6 ± 0.2Vpp
DiSEqC 1.0 & 1.2 Compatible
Channel selection type PLL Frequency Synthesizer
DEMODULATION
Type QPSK demodulation and FEC decoding
Symbol rate 1 ~ 45 MS/s
VIDEO DECODER
MPEG-2 Main Profile @ Main Level With Letter Box filter
Data rate up to 15Mbits/s
Video Formats 4:3, 16:9
AUDIO DECODER
System Decoding MPEG-1 layer I and II, Musicam
Audio Mode Left Mono, Right Mono, Stereo
Sampling Frequency 32,44.1,48 KHz
PROCESSOR RESSOURCES
Main Processor Fujitsu MB86H20 170 MHz
SD RAM 32 MB
Flash 4 MB
Component Outputs (YUV)
Connector type 3 x RCA (Y Pb Pr)
Output impedance 75W unbalanced
S-VHS Output
Video format Y, C
Output impedance 75 Ohm unbalanced
VIDEO OUTPUT/ AUDIO OUTPUT
Connector one RCA/ Connector two RCA (L/R)
Digital Audio Output
Connector type 1 x Optic
Sampling frequency rate 32 , 44.1 or 48KHz
RF MODULATOR
Modulator output CH 3-4
Video Type NTSC M
Output connector F type female
Serial Data interface
Signal RS232C interface
Connector 9 pin DB9(M)
About the Xrica X-5
What comes with the Xrica X-5:
- RS232 Data Cable (NULL Modem cable)
- Remote & Batteries
- User Manual
- AV Patch cable
$135.00CAD
MAIN FEATURES
- FUJITSU MB20H PROCESSOR
- 4 MB FLASH MEMORY
- 11" WIDE AND 7 1/2" DEPTH AND STANDS 2 1/4" HIGH WITH 1/2" OF THE HEIGHT BEING THE BOTTOM LEGS
- BEAUTIFUL LOOKING AND EASY OPERATION MENU SYSTEM
- FULLY MPEG-II DIGITAL & FULLY DVB COMPLIANT
- UP TO 9 DAYS EPG WITH 32M BYTE SDRAM
- ALPS TUNER INSIDE MADE IN JAPAN & APPROX. 1 MIN. SCAN TIME PER SATELLITE.
- USER FRIENDLY 256 COLOR RESOLUTION ON-SCREEN-DISPLAY AND EASY G.U.I
- 8 FAVORITE CHANNELS GROUP
- 4 FIXED GROUPS & 4 RENAMABLE GROUPS )
- MAX 4000 CHANNELS (TV&RADIO) PROGRAMMABLE
- AVAILABLE AUDIO INFORMATION DURING RADIO CHANNEL & SCREEN SAVER
- S/PDIF OUTPUT FOR DIGITAL AUDIO
- 6 RCA OUTPUT FOR VIDEO, AUDIO L/R, COMPONENT Y/Pb/Pr
- ENABLE TO SELECT RF MODULATOR CH3 or CH4 BY ON SCREEN GRAPHIC
- RS232 SERIAL PORT FOR UPGRADE
- MULTI-PICTURE FUNCTION 1*2, 2*3, 3*3
- S-VIDEO OUTPUT
- VARIOUS LANGUAGES SUPPORTED : ENGLISH, TURKISH, ARABIC, PARSI, FRENCH, RUSSIAN, GREEK, THAI
1. POWER SUPPLY
Type : S.M.P.S
Input Voltage : 100 – 240V AC @ 50Hz/60Hz±5%
Fuse Rating : 250V/T2A
Norminal Power Consumption : 27W
2. TUNER
Input Frequency : 950 ~ 2150 Mhz
Input Signal Level : -65 ~ -25dBm
Input Impedance : 75 Ohm Unbalanced
Connector type : 2 x F-Type, 3/8-32UNEF-2A (1 Input / 1 Loop through)
LNB power Supply : 13V / 18V, max.750mA
22KHz Tone : Frequency 22 ± 4KHz, Amplitude 0.6 ± 0.2Vpp
DiSEqC 1.0 & 1.2 : Compatible
Channel selection type : PLL Frequency Synthesizer
3. DEMODULATION
Type : QPSK demodulation and FEC decoding
Symbol rate : 1 ~ 45 MS/s
4. VIDEO DECODER
Data rate : up to 15Mbits/s
Video Formats : 4:3, 16:9
5. AUDIO DECODER
System Decoding : MPEG-1 layer I and II, Musicam
Audio Mode : Left Mono, Right Mono, Stereo
Sampling Frequency : 32,44.1,48 KHz
6. PROCESSOR RESSOURCES
Main Processor Fujitsu MB20H
SDRAM 32 Mbyte
Flash 4 Mbyte
7. Component Outputs (YUV)
Connector type : 3 x RCA (Y Pb Pr)
8. S-VHS Output
Video format Y, C
9. VIDEO OUTPUT/ AUDIO OUTPUT
10. Digital Audio Output
11. RF MODULATOR
Modulator output : CH 3-4
Video Type : NTSC M
Output connector : F type female
12. Serial Data interface
Signal : RS232C interface
Connector : 9 pin DB9(M)
I can get this one for about 42 dollars.
It is suppose to be a very new model that just came out.
Something happened to the company selling them,and they are no longer being supported? I think they shut down and went out of business?
I guess they are being wholesaled across the net now.
I do not know why, or anything else about them.
They sold for about 129 dollars when they came out. 135 can.
Pros are they are newer technology and faster than the digiwave?
About 10 dollars cheaper than the digiwave.
Cons are not a lot of people have these, info is kind of hard to come by.
May be harder to trouble shoot if I have problems with it?
Still for FTA only it sounds like it would be a great receiver for a beginner.
It is suppose to be very easy to set up and use?
Well that's it.
Tell me what you guys think.
I put the specs on here so the ones that know what all that means can compare them. Frankly at this point I do not have a clue about half this stuff.
I will have a 7 foot bud and the 39 inch prime star both on motors.
So which one would be the best for a beginner just starting out with FTA.
Thanks for your help
search
MultiSat Search
S-Video Out
Conax CA-7 Embedded
General Features
Fast Channel Change
Satellites
Lock
Smart Search
Satellites
receiver)
Type S.M.P.S
TUNER
DEMODULATION
VIDEO DECODER
AUDIO DECODER
SD RAM 32 MB
Flash 4 MB
S-VHS Output
Video format Y, C
RF MODULATOR
Video Type NTSC M
About the Xrica X-5
- User Manual
- AV Patch cable
$135.00CAD
MAIN FEATURES
- 4 MB FLASH MEMORY
- S-VIDEO OUTPUT
1. POWER SUPPLY
Type : S.M.P.S
2. TUNER
3. DEMODULATION
4. VIDEO DECODER
5. AUDIO DECODER
SDRAM 32 Mbyte
Flash 4 Mbyte
8. S-VHS Output
Video format Y, C
11. RF MODULATOR
Video Type : NTSC M
Well that's it.
