Is there anything broadcasting 24/7 on Nahuel 1 and AMC 6 so that I can lock onto it? If so please post the freqs. Thanks
Iceberg said:Nahuel 1 is aimed towards Latin America, so you probably wouldn't be able to pick it up
The only thing on AMC6 that is right now 24/7 is WVGN (NBC from USVI). However, it is very low power to pick up. Only shows a 30 quality on the Pansat
11802 H 2.000
SnockZilla said:I am on my most south sat SBS 6 setup with my motor. In your opinion should I just keep it the way it is or would you try to line up AMC 6 as the most south sat?
PSB said:Just for reference I get WVGN on AMC6 at a signal quality of.....
60 on the BEC DBS-2000
40 on the Satwork with a slightly better picture, IMO.
Iceberg said:Once you put in your true south sat and you L& L, you really don't have to do anything.
If you change anything once its set up (L &L or true south), it throws it out of whack.
