Hey, fellas. I originally posted this issue in another forum which is specific to the distribution I'm using for my MythTV setup (KnoppMyth), but the guys there don't seem to be real keen on the dvb-s stuff. You can link to the post HERE, but I think you have to be registered to see it. Alternatively, I've just copied it below.
-----Original posts------
I'm trying to add some DVB-S channels using a Twinhan 1025 PCI card. I'm able to get a signal lock when scanning for channels in the myth setup (backend setup), but it will not pull in any channels. I know everything (dish, motor, lnbs, switch, etc) are working because I can plug the same cable from the mythtv box into an STB and it works fine.
Actually, I was able to pull in some channels once. During the scan, the signal lock went to no lock and none of the scanned in channels would work. I can't figure out why that was, so I deleted the channels out of that source and tried again. Now I can get lock, but no channels to come in. I've tried various sats and tp's.
So, before I try to muddle my way through the dvb-utils and create a manual channels.conf file, did I miss something? Looks like I have the dvb tuning timeout set at the maximum level. Can I extend that somehow to see if that would help? We have LOCK, after all.
Next thing to try is a scan from an existing transport rather than a full scan. I just thought of this while typing. I've only been doing the full scan. Of course, I have to wait for the wife to quit watching Lifetime Movie Network first. Could be a while.
I added a new transport (freq 3824000 and symbolrate 3617000). When I went to scan for channels, I told it to scan an existing transport and selected the newly created transport. Still the same results. Locks, but then times out.
I stopped the backend, but could not get the card to tune using:
I'm not sure why the L band freq is 0 and the Srate is the way it is.
The switching, motor moving, and signal locking are all working in the backend setup, but why am I not getting any channels to show up? We're locked, I know they are there, everything appears to be working, ah, so frustrating.
----------End original posts--------------------------------------
And emphasis on that last paragraph! The card is sending out the diseqc command to the motor (vboxII positioner) and it DOES move to the correct position number. IT WILL LOCK on a signal, but won't pull any channels now. Sig quality is 23%-24% which seems low. I could try slaving the Twinhan from the Traxis to see if maybe the card just isn't putting out the juice.
I'm using a Twinhan 1025. That's the only card I have right now. I WISH I hadn't got rid of my 102g long ago because that worked well in MythTV. Anyone have a 102g???????
Twinhan 1025 to VboxII to BSC621 (using one coax and the built-in 22KHz switch)
Asus M2NPV-VM with nvidia 6150 video
Athlon 64 X2 dual core 1.9GHz
HDHomerun dual ATSC tuner
PVR150
Code:
root@mythtv:/usr/bin# dvbtune -f 3824000 -p H -s 3617000 -c 0 -tone 0
Using DVB card "DST DVB-S"
tuning DVB-S to L-Band:0, Pol:H Srate=-677967296, 22kHz=off
polling....
Getting frontend event
FE_STATUS:
polling....
polling....
polling....
PVR150
