Thought I would share a littel bit of my hobby project. With channels leaving 123W KU, I went whole hog getting my mini C-Band dish project in gear.
I purchased a 1.2 meter GeoSatPro dish from sateliteAV, the C-Band LNB was a dual purchased from this site on the special offer for around $20. I have two motorized 76cm dishes on my garage roof for all my KU band needs. The wife has control of one of them and I the other. We have 4 TV sets hooked up in the house and all run from a Coolsat 5000 receiver. My Coolsat runs both a motorized 76cm dish and the 1.2 meter dish dedicated to C-Band.
The only problem I had to over come was using SG2100 motors, no matter how I configured my set up both motors would move at the same time no matter what the switch matrix was. I purchased two DG 280 motors from Sadouns and they work great, have a diseqc 4x1 ahead of the motors, C-Band to port 1 and KU dish to port 2. Now when I select a C-Band sat only the motor on the 1.2 meter dish moves, and like wise only the KU dish motor moves when a KU band sat is selected. I have the C-Band LNB hooked to two TVs, one upstairs and one in the family room.
I have found NBC, CBS, ABC, Fox and the CW on C-band as well as a few others such as "This TV and My TV". Also get WHT, STO the Sportsmans and the Soundtrack Channel. A few in the clear Movie channels as well as other great programing come in. Enough extra channels to make up for the loss of channels originally broadcast by Equity Broadcasting.
The C-Band satellites I currently have viewable channels from are in order by satellite degrees: 55.5W, 58W, 72W, 87W, 89W, 91W 95W, 97W, 99W, 101W, 107.3W, 111.1W, 113.0W, 121.0W, 123W, 125W, 127W, 131W, 133W, 135W, 137W and 139W. Can't test below 55.5W as there are trees in the way.
I tried to get channels from 103W but could not, also wanted AMGTV on 97W, but found out by a answer to a post by Iceberg that the channel is now on TP 3991H on 97W and only two degrees off of 99W broadcasting WHT at 4000H, Iceberg stated that WHT over powers and interfers with AMG. If I recall Iceberg could not even get a blip from AMG using a six foot dish, hope they move the channel to a different transpondor.
The mini C-Band has proven to be very stable. Two days ago it poured rain, lost all my KU channels but all the C-Band channels came in strong and I did not even notice a dip in signal quality. Most C-Bnad signals are above 90% quality on the 1.2 meter dish with the exception of about 10% that come in around 69% quality level on the Coolsat 5000 receiver. I think being located near Omaha has its advantage for strong C-Band signal. I really would like to get channels off 103W C-Band, I see on Lyngsat that there is a planned luanch to replace this satellite, hopefully the new C-Band sat for 103W will have a bit more power. I would not say I get 100% of the channels being broadcast on c-band that the Coolsat can decode for viewing but 90% of them from each satellite that are DVB in the clear.
Attached is the photos of the two 76cm dishes mounted on the garage and the mini C-band in the side yard. I plan on moving the dish further toward the back yard and permenately mounting. Currently I have it mounted to my home made tripod, but have to move it weekly to mow. One thing I found out is after you get the lnb and scaler set perfectly that the dish becomes very stable. I can move the dish any where in the yard and re-align it back to the arc in less than 10 minutes for C-Band.
One last note to make about scaler rings and mini C-band, the conical scalers work better with dishes 76cm to 1 meter in size, the flat scaler out performs on the 1.2 meter dish. Dish geometry in play, 1.2 meter and larger must act more like a prime focus. I think the flat scaler over illuminates the smaller dishes.
