My new 1.2M Channel Master (salvaged from a dumpster) weighs only 25 lbs. with the AzEl mount removed, so why can't it be rotated by just about any of the bent-shaft HH motors? They are all rated at about 24 lbs., with any conservative engineering at all envolved in their design the 25 lbs. should be no problem. My existing SM3D22, on a .9M Fortec dish, is rated at 27 lbs.
The only problem would be designing some type of light weight adjustable bracket for mounting it to the bent-shaft. I've got some ideas, so I'm going to try it. Sadoun sells the painted steel brackets for the Fortec dishes, but I think I can fabricate one from aluminum that will be lighter. If not, I'll just buy one from them and adapt it.
I'll keep you guys posted on my success or failure.
