A arshad07 Member Original poster Sep 19, 2007 7 0 Sep 19, 2013 #1 Hello Satguys i have an unique problem with the multi connection ,Below you will see the daigram, i have set up 2 Rcvr, if rectified i will increase to 4 Rcvr
Anole SatelliteGuys Master Sep 22, 2005 11,819 14 L.A., Calif. Sep 19, 2013 #2 I've been at this quite a while, and don't see what your goal is. Take a look at the Switches Simplified FAQ. It shows a number of workable examples. . So, what sort of receivers are you using? And which satellites have your fancy? . ?
rv1pop SatelliteGuys Pro Sep 16, 2007 2,673 22 South Central Cascade Mountains and on the road. Sep 19, 2013 #3 if what you want is either polarity from each receiver at any time, you will need dual output LNBFs. You will not need power dividers. Then look at Anole's link. EASY. but you will need two cables from each LNBF (an H and a V).
