Ordered a Zinwell Sam 6802 6x8 Multi-Switch for my C Band Dishes. (Know I can't use the flexports, so basically a 4x8 Switch)
Quick question:
Is it ok to run that multi-switch with only ONE Dual output lnbf hooked up? Other inputs will not be connected to anything at this time.
I only have one dual output lnbf functioning at this time. I plan to (first) test the switch mounted at the BUD .... approx 180 feet from the receivers. I don't know if a passive multi-switch will work at that distance. I want to test it there before deciding what is needed next.
The plan is to eventually have 2 Duals feeding 3 receivers. I have about given up on finding a quality C Band quad lnbf to use with my existing Diseqc switches.
Thanks for any Info!
Quick question:
