I am trying to split a signal to 5 receivers in my house. One of the five is an expressvu HD receiver 6000 and the other 4 are the 3100 series receivers.
I purchased a Channel Vision c-1158 (SAT-HD58) 5X8 HDTV Amplified Multiswitch Link http://www.channelvision.com/specs/sat-hd58.pdf to be used with ExpressVu satellites 82 & 91. I purchased this online from a US company. Does anybody know if this unit works with ExpressVu, because the examples I get are for satellites 119 & 101.
I have a Dish 500 with a Quad LNB with 4 coax, 2 for satellite 91 and 2 for satellite 82). I assume each coax handles an odd and even transponder from each LNB. I removed the two SW22 switches at the dish and brought all 4 coax wires into the house. I took the 4 coax wires and connected one to each satellite input labelled LNB-A/14V, LNB-B/18V, LNB-C/14V and LNB-D/18V.
I am having difficulty receiving both satellites. I can get one or the other, but only when connected to LNB-A and LNB-B. C and D do not seem to work at all.
If I put one coax from 91 and the other for 82 in A & B. A switch test shows satellite 91 Odd and Satellite 82 Even. Again, I get no action out of C or D.
When I check the status of my switch, I get a message that says "No Switch Box Detected"
Help
John
Help
John
