Multiplexor Question
bfharris
21
Florida
Hi all.
I am getting my Voom installed on Monday the 26th.
I have separate lines running already for antenna and satellite. All satellite lines run to grounding block on the side of the house and all antenna lines run to a grounded splitter. My questions is with the new voom dish. I am have three receivers installed. Is the dish a three LNB dish with three separate lines that can simply be fed to my grounding block or will there just be one LNB so I will have to use a multiplexor?
Thanks.
Welcome to the forum!
There are only 2 LNB connectors. For three-room install, they will use a multi-switch. Here are the details.
Thanks for the reply.
The multiswitch is what I was wondering about.
I believe that is customer supplied isn't it or does Voom provide it?
What to expect?
hard Reboot precedures
