Hello all, new member here, as in my search travels this certainly seemed to be the best place to get quality information on all things Dish.
I am in the process of designing a media setup for a motorcoach and need a little insight. We will be using identical but independent antenna setups and using a Wally receiver at each location (front/rear of coach). First, will I be able to use both setups under a single account or does the fact they have separate sat dishes cause an issue with billing. Secondly, is there a way to utilize a single DVR hard drive for both Wally receivers, either through a network drive, or a powered hub connecting both Wallys to a single drive. I understand the DVR process formats the connected drive in a proprietary manner, but if a drive is correctly formatted would 2 Wallys be able to utilize it. The problem is, with individual drives, what is recorded at one location would not be available to view at the other and vice versa, this is the hoop I'm trying to circumvent if possible.
Thanks again for the join, and any insight you good folks might provide. Happy Dishing... Nick
