This has been one of those issues I've had for a long time now but just decided to see if there's a way to do this on a Micro HD. Search didn't find a solution for this so here goes.
When I setup to record a single program the receiver does fine. If it's off it turns itself on, records the program then turns itself off. And it does this usually without any problems. BUT, if I set it up to record TWO programs instead of just one, it will record the 1st one but NOT the 2nd? The prompt comes up on the TV screen to start the second recording but it doesn't?
And BTW, my Openbox S9 does pretty much the same thing. That V7 that I have will record as many programs as I put in it and I've done that with the recordings spaced only 1 minute apart recording those marathon programs on Decades on weekends. I don't like using that receiver though because of the funky GUI for playback that doesn't work well with the Micro HD playback.
Ennywho, has anyone setup a Micro HD successfully to do multiple daily recordings and if so, could you clue me in on what it takes to make that happen?
