Is anyone successfully sharing sat 61.5 between Voom & Dish Net?
For everyone who had Voom installed in the last 1-2 weeks:
1. Did the installer run one or both leads from the 61.5 dish Dual LNB?
2. Did they use a multi-switch from one, or, both leads even though you may only have a single Voom receiver?
I ask because I want to share a single 61.5 dish between Voom and Dish to get CBSHD as well as Voom, and, I talked to a supposedly knowledgeable guy at Voom- he said you cannot reasonably share a Dish 61.5 sat dish to still get CBSHD and Voom because:
A. they currently use a different voltage to power the LNB (Voom currently is at 11-12 volts)
B. when Voom uses up all the odd side transponders it will need both leads from the LNB at an unknown powering and switching voltage.
He said, for this reason, even single box Voom installs now are being done with multi-switches to provide for a growing program lineups use of both sides of 61.5 Dual LNB.
I am by no means certain he's right.
Separately, I have read that others have in fact used one lead for Voom and one lad for Dish equipment to receive CBSHD off transponder 20 on 61.5.
Can anyone clear this up?
__________________
Murray Kerdman
