If you don't have an external multiswitch and the receiver is reporting a multiswitch error, this tells me that the integrated switch on the dish has failed. Before replacing the switch/LNB assembly, make sure all cables are secure and the connections are free of corrosion.
To answer the OP, a multiswitch is the thing that allows the receiver to select the correct satellite and transponder polarity for the channel requested.
