One of my two 722k's ota modules is missing the main channel CBS 62 but receives the sub channels just fine. It gives the signal lost message.
Do not think it is a antenna issue as the other 722k and 211k on the same antenna work fine as do the subchannels on the one in question.
The signal on the subchannels is in the high 90's. Adjusted the antenna to make sure it was not overloaded or a multi path issue.
I can only assume the module is bad?
