My order consists of two HR24s that will utilize MRV. I would like to be able to stream to my PC from the DVRs. To be able to stream to the PC from both DVRs, will each one need an Internet connection kit? Or just one hooked to either DVR?
just one HR24 needs connected to the internet. make sure you order the internet connection kit $25.00. that gives you the broadband DECA, the broadband deca hooks up between your router or switch andthe sat. switch. that way your network is shared on the coaxial cable that your satellite uses. it's confusing at first and i couldn't grasp it. now that it is set up i get and it's a super sweet setup
Thanks. It is on my order form when I was at the retailer, but it doesn't show up on my confirmation on the online account. I think I may need to call them to make sure it is added. Unless the "unsupported" setup through ethernet works the same.
