I am expecting a new installation next week. It will have 3 HR24s and one HD receiver. It will be a SWM install. I've been reading all the posts but would appreciate some clarification on a couple of points
1. I know each DVR will be able to see/play whatever is on the others. But when it comes to recording is the To Do list separate for each DVR. In other words if you have 4 shows you want to record at the same time, do you need to go to two DVR's and set each one up to do 2 shows, or can you set all the recordings up from one receiver and it passes off the info to the others?
2. I would like to have the receivers also connected to the internet. One of the HR24's will be very near my router. can the connection be made from it or does there need to be a separate coax run from the swm to the router? If a separate coax, I would then think I would need an 8 port swm. 4 for the receivers and one for the coax to the router. Is that correct?
Pete
Pete
