Moving to folders
navychop
Member of the Month - July 2014!
61,257
29,030
Northern VA
I have some programs I'd like to move from No Folder to a folder I created. Doesn't work. I created a single folder and selecting it via Edit does nothing. Dropping down to the blank line below that folder will bring the folder name up but it does not move.
I thought this was fixed. Am I doing something wrong?
I noticed the same thing. Seems you can only file something in a folder if you setup the timer to put it there. Moving appears broken. In my case the folder menu under Edit does not show any existing folders. HWS / S311.
I remember that Moving to a Folder was a little non-intuitive.
With the display of recordings, click on the Edit button on the right (Grey). Click on a recording/s, then Edit Action (Green Button), select Move to Folder, then select the folder in the popup list so that it appears atop the list, then the Save.
That works thank you.
No Sound After Pause
Man Arrested For Ripping Off DISH Customers.
