I want to move my direct tv service to a new home with a direct satellite already installed. The house is also prewired with hook ups in every room. I only get searching for satellite signal if I connect my receiver to the room outlets and my satellite wire to the corresponding wire in my box outside. Is there anything I need to connect between my receiver and the connector on the inside wall?
I should also add that my friend brought his portable dish over and it only works if ran straight to the receiver and won't work if hooked up outside to use the existing wiring.
