hi guys,i am having a problem with my motorized ku system which is an orasat 5.0 receiver with a 1 meter dish and a sg9120B dish motor.It was operating fine,locating all the sats perfectly,then all of a sudden the receiver would freeze up when i would go to another satellite as soon as the signal would try to lock in.I would have to turn off my receiver then turn it back on and it would lock in.Now the problem is i can't get the motor to move the dish using my remote from inside my home,i can go out side and move the dish by pressing my manual button located on the dish.It moves fine from east to west.I have check all the settings on my receiver and everything is in order,I have reset the motor by the reset button,light flickers red and turn to solid green.when i command the dish to turn from inside my home,it says antenna moving but in reality it is not..i need some advice guys
ICU,
When your system (your SG9120B motor) appears to fail on you... did you look to see if the fault LED is lighted or flashing on your motor? Or is it green indicating OK? Next time this happens, confirm this. If the motor is registering a fault, it may be a motor only problem and you can work on the trouble from that direction. If the motor LED is still green, then the problem is probably with the receiver or the path of the signal between the receiver and the motor. You are going to have to break it down into sections to troubleshoot it and isolate the problem area.
Do you have another receiver to play with? That would be a good option for troubleshooting. Substitution of known good components into an inoperative or troublesome system is a great troubleshooting technique, as long as you don't see smoke! Yes, smoke and loud explosions are bad things. LOL Fire too, yeah, that's a bad result. You don't want to see fire either. Okay, okay... You know what I mean.
I am trying to lighten your spirits regarding this issue. Any failure is bad news (I have one of my own right now), but you just have to take it all in stride.
Not knowing what the exact failure could be, I can only guess at possible repairs - too many options here. Without spending time with your system and components personally, I wouldn't know it either. However, we can probably narrow the possibilities down through the art of some artistic troubleshooting techniques and maybe even a little cheating!
Can you have someone inside your home click the remote to move the dish while you are out at the dish to listen to it? Checking to see if there is a mechanical problem?
Oh, and have you DISABLED the software limits?
RADAR
