Hello everyone,
this is a GREAT forum for FTA and i thought I would ask my question here (as i have in the past as well.) I was wondering how i would go having my motorised dish be shared to two receivers. Although I have a feeling this isn't possible because one of them would have to drive the motor. and if its too much to ask. only one line going into my house. Would it be like
lnbf (both outputs) --> 22khz --> diseqc port 1 -->
then i have no idea what to do there.. maybe
receiver -> if loop through -> receiver?
would i be able to get H if the first receiver was on V?
or maybe
lnbf output 1 -> diseqc port 1 AND lnbf output 2 -> diseqc port 2 then diseqc -> receiver -> if loop through -> receiver?
or would i not be able to receive different diseqc?
i saw some splitters that are power passing on both outputs but then how would the motor get its power? i dont think that would work.
ok then this is probably where i'll mess up. i want to try using my houses existing cabling to send the satellite through (it has cable on it). the two receivers i would like to hook up will be in completely different rooms. the satellite cable comes in at one corner of my house while cable comes in at a complete opposite end.
how would i go doing this? im assuming with diplexers but I'm not quite sure how..
will i need two diplexers at the room that my satellite cable is coming in from? will i need diplexers only where there are receivers?
so sorry for how complex this may be.. I know this wasnt going to be easy when i thought of doing this.
i appreciate any help i can get!
or maybe
