First of all I would like to thank you guys for all the help. But this motor and me are not getting along.
So I'm trying to line up with satmex 5 since satmex 5 is not in my receiver or it is 6. Wathever it is for true south. 113. I even entered a tansponder and did some hunting today in the interesting snow storm outside. to make sure I was not hitting the more powerfull D* sattelite I linked my old D* receiver to the out on my prosat. I locked on to what seemed to be between 110 and 119. Good signal and such. But I'll be dipped nothing on 113. So can sombody give me a good transponder with a channel. I saw the transponder list and used that for 113. But I was not sure if there was a channel on it or not. Also I'm starting to get the feeling with my satpro dsr-500 unless I scan the satellite first. I will not get a quality line. Just a signal that is almost always 40-60% I did finally get a nods of the LNB being okay. since currently I was able to get 61.5 and 121. But not 123 or 148 or anything else. So as I figured out. I'm still not 100% lined up at all.
Also can somebody please tell me what my far west and east sattellite would be? The dish is almost all the way east to get 61.5 and I belive I should have more room. Perhaps it is the compas I'm using. I did double check all my other settings.
dish, alignment and such. Most everything picks up on the meter going across. For the elevation. In fact when I used the switch the motor I was hitting one after another and another. But only ended up with like 4 strong and 2 week. telling me I'm still off.
To bad I have all the luck picking up D*. Guess those are stronger. Though one day I was goofing around and stuff a primestar dish on my porch. Connected it up. Boom signal. I'm like yea right. But sure enough. Never did figure out what sat it was from. No compus at the time.
Anyway. Please help
thank you,
Josh
Anyway. Please help
thank you,
Josh
