Follow Up. I did some further testing today. I went up on the roof and disconnected my current set up.I raised my antenna another foot(high as I can go). I ran a seperate RG6 (1189a) from the antenna directly to the tv by- passing the sir t151 stb and the pre amp. All the station came in fuzzy, I was able to get WB(55) but theres no way I could watch it. I then ran a small RG6 line from the antenna to the pre amp, which was still mounted 12" below the antenna. I then hooked that up to the line still connected to the tv. All stations execpt WB came in clear as a bell, which tells me I need the pre amp. I then disconneted the line from the tv and connected it the the stb, and used rbg cables to the tv. All came in perfect, except WB. Channel 3(vhf) started to cut in/out a little. I tried playing with the gain, but no help. I then turned the fm trap to in and boom, 3 came in right away. Just for kicks I unplugged the pre amp and nothing worked. I also checked the channel strength for each channel, its about 75percent. I played with antenna direction a little but could get no better. I guess that WB is too weak for me to receive with my current equipment. Just wanted to thank all of you for the help, and say sorry for being such a pain in the butt.
Thanks again
John
