Missing Transponders on Some Satellites
lman12
21
Hope someone can help with this issue. I have a motorized system (36" dish, Inavacom LNBF, Disecqc 1.2/USALS motor and 9200 HD receiver). I can scan and receive satellites from 61 degrees West to 148 degrees West.
My setup for scanning in the menu is typically:
LNBF = Standard
Freq = 11250
Positioner set to USALS
Scan All
On most satellites (i.e., G10R at 123 degrees) I can receive all active transponders. Most times the Signal strength on the various satellites is 70-85% and Quality Signal range from 50 to 94% on the transponders I can receive on various satellites. On other satellities I can only receive some transponders even though I know most if not all the transponders on that particular satellite are active.
Anyone with any ideas as to what causes the problem? Any help/suggestions is welcomed.
Lo=10750
If standard linear lnb=set Local Oscillator freq to 10750, thats why you are missing part of the freq range...wish they were all that easy!!!!
Viewsat PVR 7000 Transfering movies from PVR to PC
Home made DreamBox PVR
