Missing TP in scans
Pi314
153
12
WI
Using a GeoSatpro microHD (from Satellite AV) with a Sat621 C\Ku LNB on a 90cm dish, near Madison, WI.
I'm picking up several C-band TP's on 87w and 91w.
I was hoping for 3720/H/28800 on 91w and 3920/H/29125 on 87w (as seen on Lyngsat) but not getting them.
Do those particular TP's still exist or is there a technical issue I am overlooking?
Thanks,
Pi
on a 90cm dish
there is your technical issue.
Both of those transponders are C-Band. The one on 87W I use to have a b**ch of a time here in MN getting it with the 6 footer (I dont have my dish anymore). The one on 91W was fine on the 6 footer.
I was hoping that was not going to be an issue, but apparently it is. So the lesson here is that I can pick up some c-band with the 90cm but not not all are receivable when locked on a single bird.
Thanks, I will wait until spring thaw to implement a larger dish.
Pi
Pi
The only solution to wanting it all is 10 FEET or bigger,for C band anyway.
C-Band and KU Satellite
My first post - and asking for help on 2nd LNB on a BUD
