Minimize Risk of Burn-in
DarrellP
I Think, therefore, I am.
4,298
Salem, OR
As soon as you get your brand new HDTV home, plug it in and fire it up & after the WOW factor wears off (within 5 minutes :D ), whip out your DVD that has a THX setup on it (many have it), or purchase a setup disc and CALIBRATE YOUR CONTRAST AND BRIGHTNESS!!!!! :yes
HDTV's are set on "torch" mode from the factory :mad:, this attracts attention on brightly lit sales floors but can damage your screen prematurely. :no
Keep in mind that a properly calibrated TV can look dark to you since we are used to watching TV's with the brightness turned up WAY TOO BRIGHT. Give it 2 weeks and your eyes will adjust. Also, try to calibrate with the lights at the level where you will do MOST of your watching, as the brightness levels are dependent on room lighting.
Try not to have any windows that allow sunlight to shine directly onto the screen, this will adversely affect your viewing pleasure & setup.
Now go watch some HDTV and have some fun. :p
Great points,
remember Burn in is not something to be feared but respected. Varying you programming choices is the easiest way to prevent burnin AFTER you have tuned it up. Avoid long hours of one channle left on- like FOX news, CNN or The Weather Channel. They all have fixed logos that can damage your TV with out proper precautions.
Most displays will have a setting or mode called movie, film, theater or pro which reduces the contrast by half usually putting you in the ball park for better imaging besides changing some other settings. Contrast is the biggest concern. Brightness is set based upon the ambient light in your viewing environment. Joe Kanes DVE is a great investment for those who care about peak performance.
for more info...
http://www.hdlibrary.com/viewtopic.php?t=4
Sony Vegas Pro v 10.0d has finally been released
Just bought a Harmony 650
